Any objections?
HotWire
6
Maine
Would there be any objection to putting forth information on how to hot wire a pellet stove?
Ok, explain!
I would like to see this
Okay another cause I do not take responsibility for what you do with your stove.
I started my pellet stove exp. a long time ago did not have all this digital stuff and what not. The manufacturers have complicated the hell out of it. Its very simple, I own a Comfortbilt hp42 the cheapest pellet stove that I could find that will hold 3 40# bags and is built a lot like the old jamestowns. The fire pot is very identical and the heat exchanger is too. I ran this stove for 2 weeks and the computer went thats a 4-500 dollar unit.... So I looked at how it was wired every thing runs on 120 simple. I looked at how the wire harness was connected to the computer 16 pin connector well geese you can buy them. Use your eyes figure out what wire runs what its not hard that way. I purchased a connector kit and made a hot wire kit, this stove does not have a snap disk over temp so I wired one in to the auger feed power so if it did over fire it would kill the auger and have to be manually reset. The convection and exhaust fan have there own power lines and I have a short cycle timer for a light to automate the auger feed. I have put five tons of pellets threw it no problem. it has auto ignite but to tell ya its just as easy and cheaper to light it with some starter. There all pluged into a surge protector power strip and that is patched into the power/fuzed switch on the stove. If you wanted to use the auto light just get a fan timer switch 5min is way long enough and wire it in to the igniter circuit. fixed my stove for like 60 bux total.
[Hearth.com] Any objections?
So you just rewired it to become an analogue setup.
You just stepped back a few years. People now want convenience,
not having to keep adjusting. You could have just bought a 2000 to about 2005 Enviro
FE 2 or 3. They were simple analogue stoves, and I still use a fe3 parts still available
and stoves can be bought for less than 500$
