Anybody burn any basswood?
Bushfire
Burning Hunk
192
Kennett Square, PA
Got a possibility of some free basswood and was wondering if others have burned it. Quite low on the sweeps BTU chart, but I figured it's free and already cut to length, so how bad could it really be? I don't think it's a huge amount, so maybe good for shoulder season, and if it's a hot burner like pine, maybe good to get things going in the morning?
Any thoughts out there?
I've got some Basswood = Linden. I'd compare it to poplar. Dries fast, very light, goes punky fast if left damp. If it falls down, I burn it but I'm not sure I would want to use up valuable space in the wood shed.
Just looked up the BTU numbers and they are identical. Good call.;em
This is easy picking, so probably worth it, but I'll keep it separate from my other piles so I know not to try and get an overnight burn out of it.
I cut some earlier in the Spring that I was going to use for kindling next year, but at the rate I am NOT using wood so far that might not be necessary.....it was very nice clean looking wood, and I know it is a low heat throwing wood, but for kindling or quarter splits I think it would work great!
Reactions: Bushfire
We have cottonwood here. Same amt of btus. Great for shoulder season or adding in as a restart/reload to get the stove and flue warmed back up quickly! I load it to get oak going quicker for faster damping down and longer burn out of the oak. It is a little ashy and will fill the stove quick if used alone.
Ditto to all of the above......one note.......it really stinks when burned. Keep the door of the stove closed!!
Reactions: PA. Woodsman
It burns. Just keep an eye on it. It could float away.
Reactions: LocustPocust
I found it good for the fire pit - in large pieces.
A lot of work for little heat.
bob
I have both poplar and basswood saw logs in a pile. Rest of the trees are slowly getting picked up for OWB fuel. I find that when dry the poplar is better with the basswood hardly giving enough heat to use as kindling. If you can find heartwood with a grain it makes beautiful paneling when cut into shiplap strips of 2-6" wide. Too soft for flooring, that's where i used our poplar...
