Yep. Have some ash just like described on the page.Just read this and never heard it beforeView attachment 239596View attachment 239597
Sent from my VS501 using Tapatalk
Nice book, I read it a few years ago. Where I live, no one cuts a tree for firewood if the moon isn’t on the wane, otherwise you’d have “never burning” wood. I tried to cut a couple trees with a waxing moon, and got moldy sticks in the pile... nothing scientific but since then, i uniformed my cutting habits to tradition.
I'm wondering if latitude and species has something to do with it. Hemlock, fir, spruce, birch? I don't seem to see it. And there has been a lot of wood here left in the woods to rot, and later picked up and dried, in all stages, dropped green or dead, all seasons. But there are none of those types of trees here, spruce etc. Do the Alps in Italy also have those north latitude trees?
FYI I usually chime in on white birches tendency to rot comes up so here I go again. There are a couple of reasons for white birch rounds rotting. When birches get old or stressed they rot on the stump standing up long after they are dead. The crowns die back and the rot starts quickly, working its way down the trunk. If there is any sign of die back in the crown, there is good likely hood that at least part of the tree is not worth cutting. I generally only cut birches with healthy crowns, if they are unhealthy and in the way I normally just drop them to get them out of the way as they frequently become hazard trees shedding large branches when disturbed. The other trick is if you dont have a chance to split them right away, just run your saw the length of the trunk cutting through the red inner bark. If its a big tree, run two cuts. This will buy you several months unless the tree already was starting to rot due to crown dieback. On occasion if the tree is up off the ground and its sits over the winter, water will get in the slot and freeze. In the spring I will find a debarked log with bark sitting under the log. Obviously its better to buck and split up front but I have used this slot method for years. I have one on my woodlot that I cut more than a year ago and the main trunk is completely bare and solid.
Yep, we have Norway spruce (picea abies), silver fir (abies alba), European larch (larix decidua), Austrian pine (pinus nigra), and other less common conifers, but we have birch, beech, ash, poplar and some oaks. But the vast majority of what I burn is Norway spruce. My “experiment” was with it,I'm wondering if latitude and species has something to do with it. Hemlock, fir, spruce, birch? I don't seem to see it. And there has been a lot of wood here left in the woods to rot, and later picked up and dried, in all stages, dropped green or dead, all seasons. But there are none of those types of trees here, spruce etc. Do the Alps in Italy also have those north latitude trees?
