Do you think $18,000 for a 5 ton climate master the tranquility is a good price with 1200 feet of horizontal pipe in my yard?
I have a 4 ton three stage ( two stages of geo and heat strips ) Waterfurnace that was installed about a year ago. The AC and free hot water heating is great, especially this summer. The heat is nice but it is not hot heat, it is warm heat. It takes awhile to get use to if you have been heating with gas or propane. I have 2400 feet of pipe in the ground connected to a 4 pipe horizontal loop system. I am in central Ohio.Do you think $18,000 for a 5 ton climate master the tranquility is a good price with 1200 feet of horizontal pipe in my yard?
![[Hearth.com] Anyone have a geothermal heat pump system? [Hearth.com] Anyone have a geothermal heat pump system?](https://www.hearth.com/talk/data/attachments/76/76504-6e369cd656dc1b7bfff2cfeecf40ab52.jpg?hash=sM_UpF33ty)
The trenches in the attached pics are approximately 6 - 7 feet deep. The pipe at the "bottom" of the trench on the right comes back on the "top" on the left side of the trench. The "top" of the trench is approximately two feet ( 4 - 5 feet deep ) feet from the bottom of the trench. The geo lines pull or push heat from a approximate 1 foot diameter area.
I have 2400 sf . Looking at your pics nice but didn't they put sand or some kind of material under and over the pipes? Looks like they laid it on the ground in the trench and buried it with the ground they removed. I think there should be some material in there to protect the pipe but I guess it's working good.
My ground is mostly clayish. The quote I got says hey bury it 5 feet deep.
What did your system cost?
Scott
Scott
I have a 4 ton Climatemaster unit that is water to air. I have had it for like 9 months and I love it.
-Positives, really cheap to heat each month and it does not matter what the outdoor temperature does as long as it was installed and designed correctly.
-Negatives, expensive to install and my lawn just started to look normal about 2 months ago.
Just to be clear, when you say 2400 feet of pipe you mean in 1200 feet of trench correct? 2400 feet includes both supply and return lines correct?
A typical (there really is no typical by the way) length of trench is 200 to 300 feet per ton. This is for excavated installations. Horizontally directional bored lines and vertical installation are more efficient and therefore less trench length is needed per ton.
Horizontally bored systems are very popular, especially with small sites.
The second point is another reason directionally bored systems are gaining favor. The only disturbance to the yard is for the pits needed for the headers are each end of the lines.
The last project we were involved with, the loops were actually bored below the new building being built.
The grass still has not grown back due to this years drought and trying to get it planted in the spring.![[Hearth.com] Anyone have a geothermal heat pump system? [Hearth.com] Anyone have a geothermal heat pump system?](https://www.hearth.com/talk/data/attachments/76/76529-7e860903974e0b53c1fbc52dfff8b330.jpg?hash=RRZ8xkEC2F)
Could not agree with you more. Please see attached picture for the "carnage" done to my hay field. And that was only after one trench.The grass still has not grown back due to this years drought and trying to get it planted in the spring.
Scott
I could not agree with you more about peoples opinion on how much pipe you need per ton. I talked to three different installers in my area. All three of them said they would do no less than 600 feet of pipe per ton. All three said that pipe and excavation ( for my situation ) is relatively cheap so their is no use to skimp on the amount that you put in the ground. We have very heavy clay soil so that might have something to do with it. One guy quoted my 24k for a 3 ton system but did not say how much pipe he would put in the ground. I ran away from that guy as fast as I could. I drive by his house every once and awhile. He has some nice toys sitting in his drive.
I have two 300 foot long trenches approximately 5 feet apart. Their are two pipes per trench. So yes, their is 1200' of pipe per trench. By the end of last winter, which was very mild BTW. I would say my loop temperatures were in the 40's as guess. With less pipe in the ground I would say it would of been even less.
I did alot of reading on (broken link removed) before I pulled the trigger on the system and pipe configuration.
Scott
Bigdady, where are you located? Typically the top pipe is installed around the frost depth, with other pipes below that. Generally native soils are used for backfilling. The pipe used is pretty tough, so unless there are problems with a lot of rock it should be ok to use the clay.
You may want to ask if the contractor used software to calculate the size of the system. It's very common for contractors to size a system to large. This actually creates more problems than an undersized system.
different ways to setup a loop field for geothermal.I'm in the final process of deciding between three bids for geo install in MA. A bit of a process for a retro fit and by no means cheap, but I have an aging oil/baseboard set up and and two dead AC units so replacing with geo using Mass Save 25k 7yr interest free loan and the 30% tax credit make the ROI pretty quick when factoring in new ACs, Oil Tank, and burner + labor.
300ft per ton sounds incredibly high. I've read 140-150 and at most 170. The bid I'm leaning toward is 170ft/ton over two wells.
EDIT: Also to add, I only plan on supplying heat to the cooling load and supplementing with electric and wood heat.
