Hello,
My Mother has a 24 yr old Whitfield advantage 2 T.
Sunday evening, the pellets stopped dropping, the red light on the control board continued to go on and off, and you could hear a faint motor sound when the red light was on. I took the rear access plate off and noticed the motor shaft was spinning but the shaft coming out of the gear box wasn't. I removed the auger motor, hot wired the motor. The motor was running, along with the shaft coming out of the gear box. The shaft coming out of the gear box had plenty of tourqe as well.
I re-installed the auger motor and the same thing occurred. Motor running, and shaft out of the gear box not spinning.
It appears the auger motor gear assembly is breaking down under load.
Any suggestions before I buy a new auger motor.
BTW, the pressure switch and high temp limit control are functioning properly.
I know it's an older model, but I do a thorough cleaning each year, and follow all maintance requirements.
Thanks in advance for any advice.
Steve
Steve
