My stove is a Englander 25 PDV made in 2008
Two questions...top auger was barely rotating until I bypassed power from vacuum switch that hose comes from firebox to switch. Upon doing power directly from top auger to control board the motor runs as normal...so does that mean switch is bad or something with control board and how long can I run stove without this vaccum switch?
Question 2
Bottom auger motor will run fine for awhile and continuously rotate until it just stops turning so that tells me the motor is working...so what does this mean? Is it a flat spot in the gearspossibly ....sometimes lifting and tapping motor it will start again and go for a little while....or is this an issue with the control board? Desperate need of some help as tempature goes below 30 tonight! Thanks for any guidance!!
Question 2
