auger won't stay running
help me
8
Charles town
I have a st. Croix Prescott exl 2001 the power turns on but the lights don't also the auger won't feed the pellets unless I hold the feed button. The fire burns good the blower works but it won't feed the pellets unless I keep holding the feed button. Can anybody help me with this? My thoughts is that I need to replace the control panel.
Have you tried the dollar bill test on your door gaskets? Sounds like a vacuum issue. Got the cover off of the venting:) First fire of the season hiccups. Welcome
+1 Bio
Almost certainly sounds like a safety switch issue
[quhow do I do that e="Bioburner, post: 1761081, member: 23130"]Have you tried the dollar bill test on your door gaskets? Sounds like a vacuum issue. Got the cover off of the venting:) First fire of the season hiccups. Welcome[/quote]
No h
No h[/quote]
Elaborate please:)
TAke a dollar bill and place between door and stove and close and latch the door and try and pull the bill out, repeating the process all around the door. If the bill comes out easily there probably a issue with air leaking around the door not getting the vac switch closed.
uHow eburner, post: 1761236, member: 23130"]No h[/quote]
Elaborate please:)[/quote]
Ho
Ho
Does it make any difference that it still has a analog control panel?
CAn try and find the hose that connects the switch and disconnect it and try blow back thru to the stove to see if there is a blockage. After that the stove may have a loose wire?
uote="Bioburner, post: 1761260, member: 23130"]CAn try and find the hose that connects the switch and disconnect it and try blow back thru to the stove to see if there is a blockage. After that the stove may have a loose wire?[/quote]
OK I'll try that and let you know.
Good luck. I got a couple electrical projects to work on now that the outside temps are above 50
On my Afton Bay, there are two fuses in the control box. Yours probably does, too.
If the vacuum switch fails the startup test, the #2 light will blink. It is a digital control, I don't know if yours is or not.
IF you have the old style control board, the analog one with rocker switches you most likely need to upgrade to the digital board. Sounds like the controller has gone south. Common. You need the upgrade kit to the digital board. Gonna be expensive, I think St. Croix is going OOB. Parts just went up 65% to 90% across the board, multi-fuel stove discontinued, distribution consolidated to their parent company Johnson Gas and a lot of people let go from EvenTemp. I could be wrong in the analysis of the company but pretty sure I'm spot on about the diagnosis of the pellet stove.
Reactions: Owen1508
