Autonom Robust Gasification wood Boiler support group
Here are the emission specs of the froling S4 turbo 50w-60kw boilers. How do they compare to the Autonom, I don;t how to do a comparison as autonom is g/hr and this mg/m3?
Unless the testing is done with the exact same procedures...
there is no real way to compare the results
Can someone tell me what other boiler I should be looking into that is under $15k and csa approved for at least 50kw, that is a better choice then the Autonom?
You should talk to your WETT inspector and find out if it's not EPA phase 2 compliant can it pass the inspection. In BC, to pass a WETT inspection on any new installation, the unit has to be EPA phase 2 compliant.
Reactions: salecker
Online info that you will share here?
Reactions: salecker
The only issue I am seeing with this boiler is the burn times are not as advertised. I can only get 1.5 hours of usable heat out of roughly 5-7 cu.ft of wood. This should be 3-4 hours. All the parameters are within specs for draft and flue temps.
  • Haha
Reactions: JRHAWK9
That burn time is worse than an old school wood burner...
Just to update eveyone the boiler is working well. The wood consumption is a bit more than I thought and the refractory is showing signs of wear. Other than that I am happy with the unit in general.
How much burn time have you got on it?
