So the wife and I are going to build a basement home in Missouri. WE are going to place a freestanding wood stove in the basement which has 8 ft falls. The plan is to run the double walled pipe off the stove up about five ft and out the concrete wall through a thimble. This is where we have recieved different opinions on what to do. I want to have a cleanout joint at the bottom. The house is going to be brick all the way around. The stove sales place says most people have a framed out chimeny put in with osb walls and a water barrier. Then the mason bricks over that. You run the class A pipe up that and out. Ours is going to be 22-25 ft which gives the amount of needed clearance. My builder who is also my father in law says the wood option will rot. He says we should do the clay tile option and brick around it. I called the brick company and they make a 13x13x24 in clay tile for 20 bucks. If we went with this option the chimney would be much smaller and woudl still meet the clearances and would not be combustable as the wood option would be. What is the best way of doing this thats in lasting the longest versus cost?The wood framed option has to be 4 ft wide. The clay tile option is dimensionally smaller. Please let me know what the opionions are on these choices?
![[Hearth.com] Basement chimney options? [Hearth.com] Basement chimney options?](https://www.hearth.com/talk/data/attachments/178/178494-5e5a83107718786b005deb99f61c90fb.jpg?hash=NL2WJISqBr)
