So I have finally got around to insulating my basement walls with 1 1/2 in. rigid foam to try and help heat first floor with a woodstove down there. Well starting to insulate anyway have about half of the1000 sf. done so far. I have a Napoleon 1402 on the first floor which keeps it comfortable till temps get in single digits or lower and with no heat in basement the floors are FREEZING! My goal is to at least warm up the floors above basement significantly. No insulation in basement ceiling which should be a plus I think. Leaning towards an NC-30 as I have seen great posts on here about them. Basement is 25' x 40' and not open as it has a 40 ft. cement block wall dividing it lengthwise with two 4-5 ft. openings about 10 ft. in on each end. One side is open for 40ft. but other side has a wall roughly in the middle dividing it into two sections with a 3 ft. wide opening joining them. Was planning on putting stove on 40 ft. open side across from one of the 4-5 ft. openings in hopes heat would radiate towards other side. Has anyone had trouble circulating heat in a basement with dividing walls? I'm sure fans would help if I need them just curious on others thoughts. Also there is a stairway on one end going to first floor. Thinking of putting stove on that side but it would still be maybe 10 ft. from it. Hoping heat would travel up if I put a cold air return to basement at other end? Would an NC-30 be big enough? Any thoughts would be greatly appreciated!
Here I was just sitting down in the basement enjoying my new friend (the stove) when all of a sudden I saw a wet spot on the floor and one thing leading to another as they do, I tracked it right up to the toilet. I had to tighten the sucker up a few turns on each side (which made me pretty nervous about breaking the base of the toilet), but I got 'er done and never had a problem since.... but I never figured, or even thought that it had anything to do with the stove.....
