Hey Everyone-
I'm in the middle of planning a basement renovation and I would like to take the opportunity to redo the fireplace (currently has an insert in it). I would like to replace the insert with a free standing stove. I've only ever installed inserts in our home and not well versed in chimney systems for free standing stoves.
See attached pic for current setup. My current plan is to remove all of the brick and so some sort of corner install for the free standing stove. The existing flue has a 20+ ft insulated liner in it. I assume I need to install a thimble through the wall (at location marked in pic). Planning to an extend an existing wall all the way (or close to) the left side of the current surround - blue line in picture. So, here are my questions about this.
1. I assume I can get an insulated thimble to avoid any clearance to combustible issues but not sure. Current plan would be to keep drywall at thimble location. Behind that drywall is the chimney (exterior) - The existing wall there is 2x4 construction and insulated. I did some exploring and it appears that there is at least 2" between the backside of the wall and the start of the exterior chimney brick.
2. I will need to install a Tee connector on the other side of the thimble, I assume? Assuming I am ripping out all of the existing brick, and just replacing with a 2x4 wall, the tee connector would be behind a finished wall. Assuming I need to put an access door in the new wall to get at the tee connector?
3. 45s vs 90s. I've caught bits and pieces of conversations around which is better but not sure I understand current thinking. 2 - 45s better than a 90?
I'm not sure what to expect once I start ripping the brick out. As mentioned, there is an exterior chimney behind this fireplace. My assumption is I can take out all of the brick. Insulate any open space and then put a 2x4 wall up but maybe I'm missing something?
The depth of that wood storage area (right side of the fireplace) extends out past the exterior wall. I assume I can just insulate that and cover it with the 2x4 wall?
Finally - if anyone has any ideas (or where I can find design ideas, outside of Houzz) on how to design the corner, I'm all ears! Current thinking is that I would go with something like a PE Alderlea T6 LE for the stove, but I'm still working on that decision.
Appreciate all comments, questions and feedback!
Andy
![[Hearth.com] Basement Reno - Convert Insert to Free Standing [Hearth.com] Basement Reno - Convert Insert to Free Standing](https://www.hearth.com/talk/data/attachments/254/254430-a4fffd2327c81caefc4d182e69c609cd.jpg?hash=HseacFJuan)
Andy
![[Hearth.com] Basement Reno - Convert Insert to Free Standing [Hearth.com] Basement Reno - Convert Insert to Free Standing](https://www.hearth.com/talk/data/attachments/256/256213-0fbb8b8faf0772144eb51b3872ab7e75.jpg?hash=Sdnd943rSO)
![[Hearth.com] Basement Reno - Convert Insert to Free Standing [Hearth.com] Basement Reno - Convert Insert to Free Standing](https://www.hearth.com/talk/data/attachments/264/264964-12854f28a265a510142aad532413dc64.jpg?hash=TsJ5WSqhuu)
![[Hearth.com] Basement Reno - Convert Insert to Free Standing [Hearth.com] Basement Reno - Convert Insert to Free Standing](https://www.hearth.com/talk/data/attachments/264/264972-d0aa87293bcb8e8a1e58dbf06e21ee7b.jpg?hash=_h7qrwoJRK)
![[Hearth.com] Basement Reno - Convert Insert to Free Standing [Hearth.com] Basement Reno - Convert Insert to Free Standing](https://www.hearth.com/talk/data/attachments/264/264973-f275d6964d2644aaab2e7268d391629b.jpg?hash=nsBH4ySJlc)
![[Hearth.com] Basement Reno - Convert Insert to Free Standing [Hearth.com] Basement Reno - Convert Insert to Free Standing](https://www.hearth.com/talk/data/attachments/264/264974-3b8175d135b73caa0ccafa9d50688b6e.jpg?hash=SppVwRfis4)
