best caulk to use on chimney cap?
par0thead151
494
south eastern wisconsin
I am having my chimney cap caulked , as the installers did not do it when the did the install.
I want to make sure they use quality caulk, so i will provide it for them, as i do not want to have to go back up there in a year or two to fix it when the old caulk/tar dries and cracks.
what brand/type is best to use on a steal cap adhered to masonry?
thanks
Any 100% silicone caulk will do it better than fine. It sticks like crazy and doesn't vaporize until it gets to eight hundred degrees. If that cap gets to eight hundred degrees the last thing you are going to be worried about is what is happening up there.
600 degree RTV silicone sealant
I picked some up from ACE last week
Or 500 rtv will work fine.if your cap is over 500 you got bigger problems!
Strange, but we've never caulked a chimney cap.
Come to think of it,Why do you need caulk on that cap?
B² has it correct.
I've used silicone for stove gaskets when run out of the black gasket cement gunk.
But why caulk the cap itself ? Only The flue pipe and drain cap over the pipe to the roof are sealed with silicone--lasts for many years.
I think he is talking about caulking the top plate to the flue tile. He put up a pic last week of the gap the installer left under the top plate and didn't seal it to the tile.
at home depot, they have a 3M product that the home depot guy claims is the same.
is this true?
is this true?
The same as what?
Just get a tube of 100% silicone and go up there and goop that thing.
BrotherBart said:
is this true?
The same as what?
yep goop away! that flashing looks like it needs some love too!
RAMSAY said:
BrotherBart said:
is this true?
The same as what?
i still need to call the roofer, he came to look at it but i have not heard boo from him since then.
i have since, nailed it down and used the tar stuff ot seal it temporarily. however the wood underneath is rotten and will not hold the nails tightly, so i am going to have him replace that and re do it.
i hope that does not cost an arm and a leg
the stove installer is here now.
he says that he needs to re align the flex liner so it does not put a sideways pressure on the cap. then he will silicone caulk it.
i would like to have a more secure means of connecting it, just thinking long term with a sweep running a brush up and down the liner each year...
When that caulk dries it will be like that top plate is welded on.
well it is indeed caulked.
however the underlying issue remains, the liner is at a slant which is causing it to "pull" away from the masonry portion and create a gap. as can be seen in the photo. i will check on it in a couple days to see if it moved even more.
i just noticed now that there are four pre-drilled holes in the orange masonry square that they could have used to screw the cap to the masonry square.
i suppose this is better than nothing, however it looks like a amateur did the install, not a "professional"
I dont think i will be hiring a "pro" ever again, unless i can sit and babysit them while they work.
which defeats the point of hiring out int he first place. if i have to be up there i might as well be doing the work and save the $
how long should i wait to have a fire once the caulk has been applied?
i think u could prob have one right away up there it would probably help it set up.
should i be concerned about the corner on the right of the photo, there is a void in the caulk, i plan on filling it if the caulk does hold the cap in position for a week.
I realy wish they would have done it the right way and screwed the cap to the masonry, seeing as there are pre drilled holes there...
That top plate, quit calling it the cap, is nailed down. Rest.
you don't need it screwed down. i have almost the same exact setup . i just siliconed it on and that was it. try pulling it off onces its set. that aint goin no where. screwing ='s pia.
thanks everyone for the insight. i had no idea that the silicone caulk would adhere so well.
i will fill the void that is in the photo and make sure it did not raise anywhere else before curing.
I wonder if i will notice any difference now that i have it sealed up there? before it had about 15-20% of the top plate slid off to one side.
