Hello
Just went down to the local Harbor Freight and for $39.71 with a Harbor Freight 15% off coupon I got this central pneumatic extended reach air cutter. Then I purchase a set of 3 - 3” flap discs (I recommend the 2” on the Internet for even better fit in your burnpot) and drilled a 7/32” hole in the center on the bottom side and cut the roll lock black plastic threads off the top side. I removed the cutter shield and using the cutter mounting bolt to cut threads in the flap disc and mounted it on the cutter to make a nice low profile metal die grinder to fit in the burnpot!! Wearing safety glasses when using this tool is a must because this tool rips and sparks fly! My Harman Burnpot is the cleanest it has been in many years! The old black carbon speed bump is gone and the pot is smooth as silk!
The drill driver with a wire wheel on an extension is still needed to clean the auger and the corners too.
Note: since the extended air grinder is long I suggest an air hose swivel adapted instead of the standard straight adapter which will fit better in the Harman Pellet Stoves fire box like the one below:
https://www.harborfreight.com/14-in-air-hose-swivel-connector-63575.html
Pic 01 - Original Price
Pic 02 - Clearance Price
Pic 03 - Cutter & Flap Disc
Pic 04 - Receipt Shows 15% Coupon Discount
Pic 05 - HF 3 Inch Flap Pad
Pic 06 - Drill 7-32 Hole in Center Of Flap Disc
Pic 07 - Cut Off Roll Lock Black Plastic Threads
Pic 08 - Remove Cutter Shield & Assemble Flap Disc On Air Cutter
Pic 09 - Tool has a very Low Profile that Fits into the Whitfield Burn Pot & many others!
Pic 10 - Tool Fits Harman Burn Pot
Pic 11 - Cleaning Bottom with Speed Bump of Harman Burn Pot
Pic 12 - Cleaning Side of Harman Burn Pot with Flame Guide Removed
Pic 13 - Cleaning Corners & Auger With Wire Brush
Vid 14 - VidCleaning Harman Burn Pot
Link To Harman Burn Pot Cleaning Video
ExtLowProfileDieGrinder08-RemoveCutterShield&AssembleFlapDiscOnAirCutter.webp432.8 KB · Views: 47 -
ExtLowProfileDieGrinder07-CutOffRollLockBlackPlasticThreads.webp92.2 KB · Views: 46 -
ExtLowProfileDieGrinder09-ToolFitsInWhitfieldBurnPot.webp192.1 KB · Views: 42 -
ExtLowProfileDieGrinder11-CleaningBottomWithSpeedBumpOfHarmanBurnPot.webp70.8 KB · Views: 50 -
ExtLowProfileDieGrinder13-CleaningCorners&AugerWithWireBrush.webp141.9 KB · Views: 63 -
ExtLowProfileDieGrinder12-CleanSideOfHarmanBurnPot.webp102.7 KB · Views: 54
