Big E Blower failure...please help
darkstar77
5
central ma
hello everybody-
I got a Breckwell Big E stove.... This is its 2nd season (first full)
The fan has always been noisy...
then yesterday it started screeching....then completely stopped.
The Stove seems to be burning fine still..
I could hear the fan kick on in the middle of the night and it started screeching ....then stopped....
I know I need a new fan motor...but which one..
just to be clear....its the fan that pushes the heat out the front holes of the stove.....
Im confident I can handle the motor swap...but I dont know which exact motor I need...
Any thoughts?
Need to replace the convection blower by the sounds of things. The convection blower is accessed by removing the stoves left side panel.......so says the manual.
This may help with rough location ........not sure if this is your exact stove though but it will give you a place to start looking. (broken link removed to http://breckwell.com/Manuals/P1000_2009_Manual.pdf)
and...
it looks like im finding 2 replacements availiable...
One is the breckwell....and the other is a whitfield brand...
anybody have any experience w/ the whitfield...
I cant see myself buying another breckwell fan that crapped out in a year.....
the whitfield is ten bucks more than the breckwell..
Did your crapped out blower have oil ports on it and if so did you ever clean the blower and give it some oil? That is usually a every six month thing to do.
I was unaware of any service I had to do for the convection blower...
I will be pulling stove apart this week to swap out that motor....I will let you know about oil/lube ports on motor-
also....
while I'm "inside" the stove....besides an obvious cleaning... are there other preventative maintenance I could be doing .... i.e: more oil ports etc..
also....
while I'm "inside" the stove....besides an obvious cleaning... are there other preventative maintenance I could be doing .... i.e: more oil ports etc..[/quote]
I would seriously read pages 16-18 of the owners manual for maintenance. Quite a bit of IMPORTANT/GOOD info there especially if you haven't done any of what is recommended.
Fellow Big E owner. I replaced my exhaust blower motor about 3 weeks age after 7 years of service, easy to do just swapped out the motor and squire cage which comes complete. I got mine from Kinsman stoves, Eric is a regular on this forum and a real good guy and a straight shooter. He told me about using a piece of #12 romax to clean behind the firewall, remember to clean behind the little doors on each side of the burn chamber, that is where the romax comes in handy.
I think the room air blower on a Big E is on the right side of the stove (as you face it from the front). If you open the side panel, you should see the end of the motor. If it's like the ones in the pics below, there are oiling ports. Put 2-3 drops of light (20W) NON-DETERGENT (like 3 in 1) oil into the holes. DO NOT use motor oil like for a car engine.
  • [Hearth.com] Big E Blower failure...please help
BTW, if you see the yellow plugs like in Pic#2, remove them, oil, and replace the plugs. If you don't see the holes on top, try using a flashlight and look at the underside of the motor....sometimes they get put in that way too. You could take the motor & blower apart and rotate the motor so the oil holes are facing up, like I did on my stove.
The convection blower motor is on the back side of the blower housing on the Big E and it's on the left side.
thanks guys...
i will post soon w/ the results.
the stove has been great up to this point....i have the hopper extension so I love being able to put 6 days worth pellets at setting #2... and I can leave for a week and come back to the big E still pumping heat into my basement-
I also own a harmon advanced..... (going on 10 years old w/ zero problems) ...
i would recommend both....
