BrotherBart said:
				Gooserider said:
			I'd wonder if that big E-bay stove was even LEGAL!  It sounds like the guy makes them himself, he "estimates" the output at 200K, but no mention of a testing lab.  Ditto the description of his clearance reccomendations, and I did't see word one of anything about EPA certs or any kind of modern secondary combustion technology.
If he makes less than fifty of them a year the EPA blows him off as exempt.
That makes sense (unusal for our Gov't to do something that does...) but I wonder about UL?  Would those things count as "" stoves - and need more clearances than the guy states, or is someone installing one kissing their homeowners insurance goodbye?
I'd hate to be the customer that installed it per this guy's sales pitch and then had to either yank it out or even just move it because of clearance issues....
Some of the stuff in that guy's post seemed sort of alarming:
"Heavy 1/8" outer jacket for quiet operation.......absolutely no vibration noise. You can also stack 200lbs of wood on top for drying."
Sounds like real CTC problem to me...
"8" flue for 8 inch stove pipe to chimney....... use a  reducer for 6" stove pipe to chimney."
I don't see how he can get that big a firebox cleared with a 6" opening - even some of the more reasonably sized large modern stoves require an 8" flue...  Has this been tested?
"The stove has a 2 inch space between the firebox and jacket and the air is replaced 2 1/2 times per second. The outside of the stove gets up to approxamately 230* and as you can see in one of my pics, it is almost touching wood. However, the front of the stove gets hot so you should not have anything close to it "
Again, UL tested?  I've seen the setup they use at VC to get certified, and it's certainly more than "I guess" and the numbers are a bit more exact than "almost touching" or "don't get close".  I'd also wonder what happens when the blower cuts out, either because of a power failure, or the house thermostat shutting it off...
Gooserider
