I think I discovered the source of the smoke smell on the Ashford and possibly other Bk's.
I believe the smell is coming from behind and out underneath the metal Door gasket retainer brackets. (These brackets also hold the glass in place.)
I found this out because after cleaning my chimney , I decided to replace my door gasket and found 3 spots of dried creosote drip stains on the bottom of the door... After I removed the the door gasket the source of the drip was still not visible. So I took off the metal Door gasket retainer bracket and found the source of the the drip. It was
coming from behind the retainer bracket.
I concluded that if creo is getting behind and coming out underneath that bracket then smoke is finding its way through it also.
I have been burning some center core doug fir. It has a very low moisture content ( 13%) , but is pitchy and is creating a higher than normal creostote buildup. Also burning low on days that get to 60 f during the day. All of that was creating the perfect environment for the smoke smell.
As some of you know I seal my stove pipe to help get a better quality burn and draft . And it removed the smoke smell on my stove by accident . But after recently replacing my door gasket and burning pitchy wood very low on warmer days , the smoke smell returned
. .............BUT.....
After seeing the creo drip stains coming out from behind the Door gasket retainer bracket , I decided to seal around the outside of all four retainer brackets all the way around the seam where the bracket meets the body of the door , using stove vent sealant.
What I found out is that the smoke smell immediately decreased by 90 %.....So I put more sealant on again after seeing that some of it had cracked from the heat . The smoke smell is gone . It has been a week and a half and still no smoke smell. Not sure if the sealant I am using is the best for this purpose but its showing good results.
Also , and this is pretty awesome: The creo buildup that normally occurs on the glass has decreased substantially . And the wood is burning more completely on low burns. This is a bonus.
...........This also points to the door as being the source.
i'm not sure the existing retainer bracket bolts are affecting the seal.
. .............BUT.....After seeing the creo drip stains coming out from behind the Door gasket retainer bracket , I decided to seal around the outside of all four retainer brackets all the way around the seam where the bracket meets the body of the door , using stove vent sealant.
...........This also points to the door as being the source.i'm not sure the existing retainer bracket bolts are affecting the seal.
