No fans installed, do you feel the Ashford can heat 2210 square feet? Anyone with experience with this? I live in the mid Atlantic and most winter nights average around 40, lowest usually in low teens. Half of house is cathedral ceiling...
I disagree! You've got that Alaskan perspective screwing you up, Poindexter. Note where he lives:Short answer, no.
Maybe he is upgrading houses? Gauging the hassles of moving a stove vs purchasing a different heaterI too live in md. I have an ashford and live in a 2200 sq house w vaulted ceilings. It’s insulated well, but poorly air sealed. And i basically live in a field so cold days with wind are reeally tough. Fans help but not enough. The ashford is a poor radiant heater compared to my prior stove, a hearthstone.
Answer to your question is no in very cold wx i have to supplement.
The real question is why are you asking if you already have an ashford?
I sold my old rancher with my old Ashford. I could heat it no problem any night of the year with no fans. Now that I have doubled my living space, I'm wondering If it'll be able to keep up most nights. I just bought a 2017 Ashford White Stone Enamel. It gets hooked up on December 7th. I do close off two rooms upstairs, so I'm actually only heating around 1800, but half of that space is a vaulted ceiling. Thank you ALL for your input with your experience. Helps me get a feel for what to expect in a couple weeks...honestly, I'm happy to expect running the stove wide open. I don't like stoves being shut down most of their life. Not good for the stack or stove.I too live in md. I have an ashford and live in a 2200 sq house w vaulted ceilings. It’s insulated well, but poorly air sealed. And i basically live in a field so cold days with wind are reeally tough. Fans help but not enough. The ashford is a poor radiant heater compared to my prior stove, a hearthstone.
Actually I don't see that much difference between run the stove on the high side compare to the low side. I still can get good heat finding a setting on the low side where most of the time there are no flames going on. The key is a hot burn after reload at least for me with the Princess. I can't speak for the ashford. My ranch house is not near air seal or tight, not even with all the remodeling done over the years. It is +/- 2400SF. For me is not worth to see all that heat going up the stack when on high. I always can find like mentioned before a low side settings. when it dropped last week to 22 and 19 degrees, just with the fans on low, that did the trick. 75 degrees on one part of the house and between 67-69 the other part. 64 upstairs.
The settings of the thermostat was almost the same as always when i don't use the fans. Just a little more of wood consumption. Till now I always run the thermostat under 3 o'clock. By 2 o'clock we can say. Sometimes with fans on I can run it lower and still keeping the house at nice temp and wood consumption is almost the same. 2-3 hrs less maybe out of the same load?. My schedule still between 20 to 24 hrs.
Thanks everyone! Very pleased and anxious to get the natural gas turned off. Grateful to have lots of seasoned wood ready to burn. I'm hopeful I'll be able to heat the house to a comfortable temperature without the fans. I use box fans to move cold air toward the stove, and ceiling fans in rooms. As long as the house is over 67, it'll be warmer than what I keep it on gas
I got a new stone white enamel.So are you moving the BK or getting a new one?
Sent from my SM-G900V using Tapatalk
Well, I wouldn’t call it “a lot of oil”, but this is partly true. I should put a finer point on my past statements about this, for the purpose of this thread.Ashful, you also burn a lot of oil... don't forget that part. The stoves aren't heating your place by themselves.
Well said, Ashful. You are right, I am definitely in a warmer climate. Phili is way colder than us even though you are only 2 hours north. The ocean keeps me very moderated!Well, I wouldn’t call it “a lot of oil”, but this is partly true. I should put a finer point on my past statements about this, for the purpose of this thread.
I burn supplemental oil Monday thru Friday, when I setting my stoves for 12 and 24 hour burns to match my work schedule. Basically, I run these stoves on a schedule that suits me, and let the boiler pick up the slack.
On weekends, when I’m willing to run the stoves harder and faster, they usually keep up. The exception is when temps dip way down for extended periods, such as single-digit nights and days in the teens, and then there’s just no hope the stove in the older/larger un-insulated part of the house can keep up.
But, the OP’s house is at least 200+ years newer, smaller, in a warmer climate, and most importantly... not made of un-insulated masonry. I also assume, when someone asks if a given stove can “heat” a given space, that they’re not completely ruling out supplemental heat for those rare few coldest nights of the year, but I should have also been clearer on that.
Can I ask what shop you purchased through?I got a new stone white enamel.
Do they have a good floor selection? I like to window shop and Bylers in Dover is tired of seeing me lolFireplace Specialties in Selbyville
