I need to replace the door gasket and the window gasket on my stove. The door gasket is straightforward enough, but I'm slightly anxious about the window gasket and wonder if anyone here has replaced theirs and can advise. It's an adhesive-backed piece that you form around the edge of the glass, before clamping it back to the door. I'm wondering how to deal with where the gasket material may bunch up at the corners when its folded into the u-channel shape (to fit around the edge of the glass). Should I cut notches there ? Also, it sounds like the brackets that hold the glass to the door are attached to studs on the door frame. I'm concerned that the nuts will be frozen and studs might shear off when I try to remove them. Maybe I worry too much ?
