Hi all
First time poster…
I’m having problems figuring out why my princess isn’t performing up to my expectations or anywhere near what I’m reading others are getting out of their stoves.
Here’s the situation:
Moved into the house in the spring with the stove installed. It is a corner install with a field stone hearth and surround with a wood mantle about 8” higher than the stove. All clearances are beyond the minimum specs. Chimney is straight up with about 15-16’ total. No bends or angles. Fresh air supplied via 4” duct from the outside wall directly to the back of the stove.
Burning previous standing dead spruce that’s been split and stacked for almost 2 years. Stacked outside so there is snow on it that I brush off as much as possible before bringing it into the house. I’ve started bringing it in to warm up prior to burning but it doesn’t seem to make much difference. I’ve used this same wood in my previous Osburn stove with no issues and good performance.
I have to run the stove nearly wide open to keep the cat active. I’ve replaced the cat as I thought it was worn out from the previous owner. It didn’t seem to make much difference. As soon as I turn the fan on once the stove is hot the cat temp starts to fall and cannot keep up even with very low fan speeds. Running with no fans will keep the cat active but only at about 1/4 to 1/2 of the active range on the thermometer. Running at nearly wide open I’m only getting 3-4 hour burns in a full load with very little heat output. The house is about 2200 sq feet all on one level and I cannot get it warmed up enough for the furnace to not run. Draft seems fine, the only thing I can think of holding the performance back is that the fresh air intake is too small and isn’t getting g enough air to the stove? It’s only about 3’ of insulated pipe from the wall to the back of the stove. Is 4” pipe large enough?
I have a bypass gasket and door gasket in order to eliminate those factors.
I’m was really looking forward to using the stove to its full potential but I’m quite disappointed so far.
Located in central Alberta. Around 2500 ft elevation.
Thank you for your help in advance.
First time poster…
