The locust around here grows like a corkscrew.... which works fine cut into 16" lengths... no so much for boards... and BTW.... Black locust is toxic, esp the cambium layer...
Nailing the framing together was not fun. I would recommend against trying. We layer the deck down with regular deck screws with no issue. It took them very well in fact. We only drilled pilot holes on the ends. All of the middle holes we just plowed on through. You need a heavy duty corded drill though. My li ion was not up to the task. It's great wood and should stand up to the abuse of shoveling much better than the pressure treated.
The old green PT that had copper arsenate would last 150 years or better but from what I have seen of the new green PT 10 years is a long time. Used the new on my deck 7 years ago and will never again, already needs to be replaced. Decks I built 25 years ago with the old PT are still going strong.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
