Blaze King pi29 insert - shroud overlaps and not flush with the stone surround
qmhearth
1
East Northport, NY
I’m very excited to get started with my first fireplace. I’ve been in contact with many fireplace and chimney companies and I was suggested with a fireplace insert to boost efficiency.
After consulting, I received an estimate to install a blaze king pi29 with a mandatory shroud. The insert fits the firebox dimensions. However, I’m concerned with the mandatory shroud.
According to manufacturer’s measurements, the shroud would overlap some of the stone surround. With the shroud, the measurement is 47”W x 33”H
[Hearth.com] Blaze King pi29 insert - shroud overlaps and not flush with the stone surround
The shroud would not sit flush with the stones. Would this be an issue in terms of functionality? Or is it merely aesthetics? If aesthetics, is it possible to remove shroud later on and then redo the stone surround with bricks or something flat for the shroud to sit flush?
Furthermore, what are options to remedy if it affects function of the insert? Should I grind stones flat? Or since the mortar is failing, remove the stones?
I will definitely speak with the fireplace specialist to see how they’ll handle it. But I would like opinions from my fellow fireplace enthusiasts. Any other advice would be appreciated.
See below for images on how the stone surround was installed.
And picture of the firebox area
It is not aesthetically pleasing but the insert is connected to a liner so there shouldn't be any flue gases to worry about.
The surround can be removed later if the stone facade is to be replaced and then replaced on the insert.
The manual shows the surround at 29" tall by 43" wide. The insert itself is 35.5" wide by 23.375" tall. Perhaps run the insert with no surround for now. and install it later once the wall redo is completed. Another option might be to have a custom surround made that fits inside of the stone for a shadowbox look.
Reactions: qmhearth
