I have had my Blaze King Princess Insert for 4 seasons now. I have been having an issue with the CAT I believe. The first 2 years I had no visible smoke coming out of the chimney but now I have had smoke when the CAT is engaged and the CAT Temp is above the 12 o'clock position. I also have had to clean the chimney twice this winter and it had a lot of creosote in the top 5 feet of it. The chimney is a masonary chimney on the outside of the house and has a block off plate at the bottom and top. I have a stainless pipe running inside the flue and it attaches to the stove. No insulation though. I have been taking to Chris from Blaze King about it. Do I need to pull my CAT and clean it? Was thinking of buying a new steel CAT. According to Condar's website the CAT should be replaced after 4 years of 6 months of burning. Any clues as to what the issue is ? My glass stays clean all winter. I am burning wood that has been seasoned 2 years so that is not the issue. Also, I put a new door gasket on just in case and i adjusted the by pass door. Only thing left is the CAT. Thanks Pete
. Maybe burn an incense stick and see if it sucks the smoke in anywhere.
