Block Off Plate Worth the Work and Cash?
OregonMike
19
Portland, OR
If you're in the NW you're probably feeling the first cold snap of the year. I've been able to heat the house pretty comfortable with just my Lopi insert but since its gotten in the 20's the furnace has been burning some cash. Has anyone installed a block off plate after installing an insert. Did it make a noticeable improvement? I've bot a Lopi Revere installed into an old masonry Fireplace and chimney, the top is sealed but I'm guessing a lot of heat is being wasted up the chimney liner.
Yes it makes a big difference
There are many threads on this topic where the owners have reported back seeing a notable difference. In one I recall a Jotul C550 owner that was looking at replacing it with a larger insert. After installing a block-off plate they were able to heat the place well with the C550. The difference is most notable with exterior wall fireplaces that have their back exposed to the outdoors. If there is room, adding a layer of insulation behind the insert can also help.
