Blower for LennoxSuperior AD14454
Tunacity
4
08742
***edit*** model number is incorrect in thread title. It is HC-4320A.
I have a Lennox that indicates for blower assembly FAK 1500. The space under the wood burning fireplace blower vent allows for about 3 3/4" clearance. The vent is about 11" long.
Does anyone have a recommendation for a blower that will fit?
I do not currently have a wall switch. I expect I will want a thermostat and speed control.
I have been challenged at finding a replacement. Any help would be greatly appreciated.
Rob
Sent from my SAMSUNG-SM-G870A using Tapatalk
Thank you very much.
That one is about 7 1/4" wide, very small wheel/fins and vent channel.
Is there anything in between that and 11"?
Rob
Yes sorry I grabbed the wrong number. The model is HC-4320A.
Hart's Hearth lists it. Not sure if still in stock
(broken link removed to http://www.hartshearth.com/ProductCart/pc/viewPrd.asp?idproduct=15444)
Awesome. I searched a ton and did not find it anywhere!
I will check with service to see if this is the best fit as I don't see specs listed and no returns.
I can't help but thinking a longer motor would blow more air. Will see what they say. Opinions here welcome.
Many thanks!!!
Grainger has several of varying widths if you want to try a non-stock unit.
