Temps just started getting colder in Long Island ny. Just trying to see if the blower would be better on high or low for over night burn. I have the regency ci 2600 if that makes a difference.
I wasn't sure if the blower on high would cool the metal in the chamber to fast and blow cooler air.It doesn't matter WHERE you set the blower control.
It has NOTHING to do with the actual combustion of the wood
that is INSIDE the firebox.
All the blower does is move air around the OUTSIDE of the firebox
& farther out into the room before it rises to the ceiling...
I've taken the heat measurements. It does. I operate my blower in "Auto" and as speed goes up metal temp, both of exchanger and stove, goes down.I wasn't sure if the blower on high would cool the metal in the chamber to fast and blow cooler air.
If it's a cat insert, it'll affect the cat temp as well. I can tell the difference in the intensity of the glow when the blower is off, low or high. If I've got quite a bit of wood gassing and the cat is really cranking, the blower doesn't have as much effect. But if trying to run low and slow, you are closer to the balance point; You could even crash the cat, though that's pretty easy to avoid, and not generally an issue. Now, the OP's insert is a hybrid, so there's another variable...determines the steady-state operating temperature inside the box.
What type of wood, and how fast it burns, is another factor. I'm still trying to figure out the dense woods like Hickory, which seems to gas slower. This is my first year with a lot of dry Pignut and I'm thinking I may have to split it smaller in the future to speed up the gassing a bit in my cat stoves. White Ash, for me, strikes a good balance between steady gassing and a long burn, and split size is less critical.My lopi likes to run good and hot. If I have the blower set too high I cannot maintain secondary burn and end up going through wood faster because I have to add more primary air. I'm burning good seasoned ash.
Wolves1, I just want to thank you for all the time you have put into answering fire junkies questions and helping out on the CI 2600. I have done a ton of research, including reading through these monster threads over the last 4 months, and it definitely swayed my opinion from going with the FPX Large hybrid to the Regency CI 2600. I have it installed two weeks ago, but the installers tried giving me their floor model from 2014. When I saw the date I told them no way...not dealing with everything you guys had to. Anyway, you've been a big help, and cut the learning time down (I HOPE) on this unit. I will of course be back on if I am wrong.Thank you all. I have found the temps in the first floor do run 5 degrees warmer with fan on high with temps in the stove not effected.
Hi I’m here on Long Island too. I just had the ci2700 installed. How long does it take for the blower to kick on when it’s in auto mode. I’m at 730 degrees for about 25 minutes now with the bypass closed and the draft midway. Debating on just turning it on manual.Temps just started getting colder in Long Island ny. Just trying to see if the blower would be better on high or low for over night burn. I have the regency ci 2600 if that makes a difference.
The thermostatic snap switch is located on the bottom of the stove/insert. It takes a while for a hot coal bed to develop and the mass of the stove to heat up enough to warm that area on a cold start. If it doesn't come on soon it could be that the snap switch is not making firm contact with the stove body and needs to be tightened a bit. Or it could be the switch is defective and needs replacing.Hi I’m here on Long Island too. I just had the ci2700 installed. How long does it take for the blower to kick on when it’s in auto mode. I’m at 730 degrees for about 25 minutes now with the bypass closed and the draft midway. Debating on just turning it on manual.
Have you compared room temps to running the fan on low speed under the same outside temp?Thank you all. I have found the temps in the first floor do run 5 degrees warmer with fan on high with temps in the stove not effected.
I only do this when it is very cold outside and I am pushing the stove for heat. Our fan speed is variable so I normally run it on medium with the weather in the high 20s to freezing and not at all if above 35º outside. Medium to low speed is reasonably quiet. Running the fan on high is too noisy for me in our living room, so I only run it on high if really needed. It's one of the reasons I sold the pellet stove.So the bottom line is I always run the blower full speed to get the most heat out of the wood. If it's warm in the house, I'd cut back on the wood as opposed to cutting back on the blower and sending that extra heat out the flue.
