Hi Everyone,
I'm brand new to the forum (have done some lurking) and brand new to OWB's in general. I apologize in advance for any of my ignorance.
My wife and I recently purchased a house that already had a Hardy H3 on the premises. I was pretty excited when I found out the property had a boiler so now I'm really just trying to get a firm grasp on how everything works.
Both the construction of the house and installation of the boiler occurred at the same time in 2007. The house comprises of four heating zones (garage, basement, first floor, and second floor). The garage and basement have radiators. The first floor has baseboard. For the second floor, the boiler connects to the air handler in the attic to supply heat through the forced air vents. The garage and basement each have a digital thermostat while the first and second floor have one of the round mercury based thermostats that ties to the boiler only. There is also a separate digital thermostat on the first and second floor that operate the floors respective heat pump. Currently, in the week since the boiler has been running, I only have the valves opened that run to the basement and first floor.
The biggest question/concern I have right now is that the blower to the boiler doesn't seem to be shutting off. My first suspicion (based on my limited knowledge) is with the L6006 aquastat itself. If I take the cover of the aquastat off, I see the set point dial that is at 170. There is another dial located toward the rear of the stat that after some research appears to be the differential adjustment wheel. This is set at about 13.
If I manually start to slowly turn the set point dial down, the blower will shut off eventually. I've had it shut off at around 155 and another time it wouldn't shut off until the dial hit 140.
I thought perhaps my fire just wasn't getting hot enough to heat the water to 170 but I've had it going for almost a week now with twice a day loading so I'm not really sure if that would be the issue or not. Every time I have gone outside to load wood into the boiler, the blower has been running.
Any help and guidance would be greatly appreciated. Thanks!
