ARGlock said:Do you all have a link for the best Magnehelic gauge and whatever else I need with it? I need to get one to test a new PE Warmland that is smoking up the glass. The stove venting is a ICC PCOT Cleanout 90 right behind the stove adapter up about a foot to a 90 and then straight out 24 inches through the wall to a Jet Cap.
How would I hook the Magnehelic to the Pacific Energy Warmland?
Thanks Amigos,
AR
I got my gauge off ebay. But grainger has them.
The setting info is right in the manual.
Draft Damper
The PS45 stove has a draft damper located at the left side
of the stove directly in front of the combustion blower. After
the stove is installed the Draft Damper will need to be set for
the vent configuration. Using a magnehelic gauge, adjust the
Slider until a reading of .12"-.14" is achieved in the firebox.
The sampling hole is located in the top of the ash box, above
the ashpan. To reduce the draft, move the adjuster toward the
center of the stove.
Lots of stuff can be learned about the stove if you actually read the manual.
!! You are the Stove GURU
