We need to see the front of the stove to be sure. Is there Norwegian writing over the door?
![[Hearth.com] Bought wood stove [Hearth.com] Bought wood stove](https://www.hearth.com/talk/data/attachments/148/148900-31d87401523f3657e9f8cab10cf1379c.jpg?hash=qOJHT4OLah)
If the top front plate over the door is blank and doesn't have the Norwegian text it's a knockoff.Not sure exactly how I will determine. When I searched for some information on whether it was a jotul or not the metal plate where all information would've been was too faded to read.
Thats probably the one that i will end up with. The city prohibits the install of used stoves in houses. You can however put a used one in the garage. The insurance company is fine provided it is WETT inspected.The F118CB has ribbed sides and a black bear in a circle in the middle.
Is the base of the 118 the same size as a 102?The F118CB has ribbed sides and a black bear in a circle in the middle.
Oh, thanks, I thought it looked longer.Do you mean the F602? The F118 is longer by about 6 or 8".
Yes, probably a Scandia from Taiwan.
If you're not going to keep it, why bother? Lug it to the back yard and burn all that stuff you don't want to bring in the house and do some cooking on top at the same time, dutch oven with some hearty soup.Yeah so I found the "Taiwan" imprint on the back of the stove. Must be a scandia. Not sure if I am going to keep or not but do you have any suggestions for cleaning it up? Like I said it has a good deal of surface rust on it but am hoping to either clean it up with some CLR and a light brush or maybe paint it with some stove paint? What would you suggest?
