Just bought a used p24 insert and need some info.
First I want to know how old it is. The serial # is WH-94 53415, It is auto ignite with an analog control board, but there is no slide switch at the top for (on/off-high/low-manual) like the user manual shows. Everything else looks the same as the book shows.
I can find the newer style analog control board on the internet. Is it an easy retrofit to change this out?
Last but not least- the stove is hooked to a thermostat that seems to work keeping the temp about where I set it. will any low voltage thermostat work in this scenario? We are talking one red and one white wire, so I am thinking cold -wax on- warm wax off- is about all we need.
Any help, tips, info will be greatly appreciated.
Steve
Steve
