Hi friends. I have a woodmaster 4400 with a heat exchanger connected to the plenum of my forced air furnace. My question relates to warming the basement of my house. There are no ducts in the basement The concrete walls are approx 12" thick. I'd like to provide heat in the basement ( to warm the floors and provide some radiant heat ) and am wondering if it is logical to put in either fin or older cast iron radiators that pull btus from the water either on its supply run or the return run to the furnace. By the way I also have a heat exchanger to assist with my electric hot water heater. It is on the return run. Do you recommend one run over the other and short of insulating the walls do you think this will help to warm the basement?
