Good morning,
Was running my Hearthstone Manchester last night with some well seasoned live oak on a cold start. (hybrid stove with secondary burn and Cat) Everything was going good but I normally have secondaries off gassing thru the first couple of hours once the wood gets charred but not much was going last night. I take the air intake down in stages to prevent the fire from going out like usual. Cat gauge showed in the lower part of the active zone on my last stage of shut down so I engaged it and shut the air almost all the way like I normally do which is around 3/16" from being fully shut.
Stove top temp inside grates at this time was around 350ish according to infrared (Stove has a cast iron jacket over stove top) and the condor pipe probe inside my double wall was reading around 650.
Pipe key damper was wide open at this point and I stepped away for 15 minutes.
When I cam back the condor probe read 1200 and I could smell paint. No visible flames whatsover in the box. The Cat probe was basically on the border of the "too Hot" zone. I panicked and closed the key damper all the way (Icc damper still allows 20% of flue gas even during the completely shut state) and the pipe temp came down to 850 ish within a 5 min time frame. Stove top on the grate/fin area read 450 to 500.
Ive got a 27" stack straight up with double to the ceiling, then class A through my attic and out the roof. Pulls hard which is why I installed the damper.
Was hoping someone could explain to me why and how did this happen? I've never seen the temps rise that fast, especially with no flames in the box. As mentioned I am use to seeing a hard secondary combustion but there was none during this time period last night.
Should I have used my key damper earlier in the burn?
