Hello everyone, been away for a while. I was planning on doing all my insulation projects during the summer but procrastination got the best of me. I've read a good deal about insulating basements, crawlspaces, and attics so I'm just about ready to tackle this. I'm hoping some of you insulation gurus can help me. My questions:
1) I'm planning on using foam board insulation as the vapor barrier along the exterior walls in my basement and crawlspace. I'll most like go with a 2" board with a R10 value. I'll also use the board to seal the rim joists and spray foam cans to ensure proper sealing. Crawlspace will also have plastic on the floor with overlap onto the exterior walls. Do you think it's absolutely necessary to frame a stud wall behind the boards for support and use additional fiber glass sheets in the cavities? Would you do the same for the crawlspace?
2) Using drylock sounds like a bit of a toss up. The 2" foam board will act as the vapor barrier so I'm not sure if I should waste my time and money on buying drylock. Do you think it's worth it?
3) I have red brick for the crawlspace foundation walls. Would you apply cement or some sort of coating over the bricks to achieve a uniform surface in which to glue the boards or is that unnecessary?
4) If I frame a midget sized stud wall for my crawlspace, will that lead to possibly termite issues?
I think my attic insulation plan is good to go. I'm just going to remove the ancient insulation in the rafters (I think that's what they're called lol) and lay down new fiber glass rolls. I'm also planning on making paper insulation and using that to get hard to reach areas.
Also, I sold my undersized insert and bought an Englander 30NCH for $649 from HD after seeing the deal on this site. I think I'll save it for my eventual garage/man cave. I read through the manual online while I await the delivery and I'm a bit confused on a few details.
5) Do I need stove pipe from the stove to my liner? I'm planning on using the Flex King flexible liner. I was thinking of doing that from the top of the chimney right to the stove. I also wanted a clean out T but I guess that's not possible. The stove will sit inside my mason chimney and vent directly up about 25-30'.
tsunamis protection maybe?
