So I recently bought and installed a US Stove 6041 insert. I have been burning for 1.5 months now and thus far have enjoyed the heat, learning experience (many thanks to all of the information that everyone shares on this site) and keeping the LP man at bay. What I am experiencing now is something very different, and I am not too sure that it is a problem necessarily. In an attempt to reduce air leakage around the firepot I crimped the tracks that the ash cleanouts slide in. The makes them air tight and eliminates air being pulled out of the stove that did not move through the firepot; and I did not realize how much air must have been moving through them, because now I have to relearn how to use this stove now.
Previous to crimping the ash clean outs I could run the stove on level 5 (max) feeding 5lbs/hr all other settings are auto and room fan max always. The heat coming out was at 265F and was heating the room up very nicely. After crimping the ash clean outs to seal them, I am running on level 4 and the stove is shutting down because of high temperature. Shutting down is bad, but it seems like I am spitting out much more heat than I was before and have even begun trimming pellet feed down and lowering the draft fan speeds. Unfortunately I cannot check the output temp because I dropped my thermometer and broke it, but I am going to buy a new one and see what it says. I am still trying to get the pellet burn balanced again, but the flames are much more active and it seems like I am capturing much more heat from this stove.
It was -17 last night with a wind chill at around -35, my basement was 73F running on level 4of5 and the stove was still dropping to level 1 periodically because the thermostat was satisfied. So unless I am mistakenly chalking up the high temp issues to increased heat output and capture instead of a faulty snap disc I think that I have saved myself some money in pellets.
Has anyone else experienced a paramount increase in heat output like this, especially with this stove?
		 Make no mistake, the company who built this unit WANTS to get as much heat as is possible (to sell stoves) Any modification to pellet stove without prior approval is taking chances with your life (if you sleep with it running)
		![[Hearth.com] Can a stove be too efficient? [Hearth.com] Can a stove be too efficient?](https://www.hearth.com/banners/caluwepellet.jpg)
