I am trying to design a code acceptable way of getting a Class A chimney out the back of my roof and lined up on the same plane as my masonry chimney, so I can later put a chase around it and have them look symmetrical.
I made a scale model of the profile of my home, and my idea.
Basically I want to run the chimney from my living room on the front of my ranch house, out the back of the house. The 30 degree offsets will not allow this without running straight up from the other side of the attic carrying beam. Can I install a Wall thimble, then from the thimble, run a horizontal run of Class A chimney pipe through the basement stairwell over to a Tee. In other words can I make the Tee an effective 90 degree elbow about 3 feet from the thimble or does the Tee by code need to be connected directly to the thimble?
Also... Once I get the chimney out the roof, does it need to be 10 feet away from the other chimney if I want it to be the same height as the masonry chimney?
