Can you identify this direct vent natural gas unit?
eliteconcept
9
46360
Need help identifying this direct vent gas fireplace. No sticker or rating plate anywhere on it. Id figure it to be from mid 90s. House was built in 1995/1996 .
[Hearth.com] Can you identify this direct vent natural gas unit?
Looks like an early 2000s Heat & Glo unit. Isn’t there a rating plate attached to the floor in the valve cavity?
Negative. There looks like there was at one point there is some evidence of sticker residue but i can't be for sure. There is no other plate or identification label anywhere on it. Near the controls or on the top
Post a pic of the log set & the gas valve. Maybe that can narrow help it down.
Wow! Looks like an old DSI unit. I haven’t worked in one in DECADES. It’s been so long, I can’t remember model numbers. Are there other homes in your neighborhood with the same units?
Im not sure we moved in just last year i haven't asked around. It works great but the glass busted a couple weeks ago. DSI, is that direct spark ignition? If so you are right i think. I flip a wall switch and it starts up. Its nice. Do you not work on them because they are not common or because they are highly reliable, or they don't make this kind any more? Just curious.
It had an orange gasket on the glass, roughly 1/4in wide an 1/4 in thick. Ive been trying to figure out how to find a replacement. It is looking like rope gasket is my only option.
They stopped making DSI units about 2000, I think. The only times I did work on those units was to change them from Direct Spark to a standing pilot. Contact your local Heat & Glo dealer. He might be able to help you with IDing the unit & matching the silicone gasket.
Thanks! I gave them a call but they said they would need a serial number or model number to help identify the proper glass/ gasket :(
Maybe if you brought the gasket to them, they could match it…
