Cast Iron Stove in Outdoor Workshop- Problems??
OntarioWinter
12
Ontario CA
I'm looking at purchasing a second hand (approx 15yo) Jotul Model 3 to recede into a stone hearth/fireplace that I just completed in my uninsulated backyard workshop. I'm wondering if the sharp changes in temperatures when lighting the stove at ambient outdoor winter temperatures could lead to cracking or other issues. Should I hold off on the Jotul and maybe stick to steel?
Also, the clearance of the top of the stove will be about 1 inch on the short legs, would it be conceivable to set the stove in place with no legs on the stone hearth?
Here are a couple shots of the new hearth
[Hearth.com] Cast Iron Stove in Outdoor Workshop- Problems??
Welcome to the forums!
OMG that is nice! And it's for a shed?! I can't imagine how nice your hearth must be in your house!
I'd go steel, personally. Something tells me (and I could be wrong) that the cast iron won't like going from -25 to +250 C in 45 minutes....But I could be wrong!
Andrew
That is a beautiful fireplace. Have to ask why build it just to install a stove? It's too nice to cover up. Maybe install an insert but leave off the surround?
The three has an ash pan assembly that would preclude sitting in in there without legs. With it removed there would be an open grate in the bottom too.
Unless it is the F3 TD. I don't think it had the ash pan.
That is some nice looking stone work. I'm going to build a 36' ft dual flue chimney , up through my log home and that is the look I want . Awesome looking hearth...
Thanks for the compliments guys! I built the hearth with a stove in mind all along, fireplace just doesn't do the trick to heat the uninsulated 500 square feet. Here's the link to the stove I'm looking at. Can't quite make out the ash pan. Either way my main concern is whether the temperature fluctuations will cause the stove to crack.
(broken link removed to http://www.kijiji.ca/v-home-indoor-other/guelph/wood-stove/1036512776?enableSearchNavigationFlag=true)
I couldn't imagine any issue, IMO. I recall that thermal expansion is fairly linier. So starting the cold stove at 0For 60F and bringing it to 500 or 600. The starting temp is not a big deal. You do need to expand the complete stove evenly. Every piece needs room to expand. So slower the temp rise the better. This needs to be part of the stove design.
Given the uninsulated walls, I would be inclined to put in a larger steel stove or insert body of a larger size. maybe a Buck stove? The F3 firebox is small.
What is with the beam going through the upper part of the chimney? How is this isolated from the heat of a fire or more importantly many fires?
The 'beam' is just a 2x4 brace wrapped in boards. It's about 8 feet from the opening of the fireplace so I didn't think it would be a problem. It's anchored to a stud behind the stone facade. No contact with the actual flue pipe if that's what you were thinking.
As for the size of the stove I'm looking to get enough heat to work comfortably but don't want to get the place too warm/dry as I'll be storing some old wooden canoes in there in the winter. I'd be content with 60 degrees.
Thanks! That's what I was hoping to hear. I just realized that my father's had an old VC Resolute in his patio green house for years and there's no cracking as far as I can tell with thousands of cold starts.
A proper chimney should have 1" clearance from all combustibles. Heat is transmitted through the stone fairly well.
Why would you go to all the trouble to build a masonry fireplace, when all along you wanted a wood stove?
I wanted the look of masonry fireplace with the the increased efficiency of a stove. It was a pet project. Other than the sand and masonry I sourced all the material for free and the labour was done by myself and my father. It fits the look of the building too.
[Hearth.com] Cast Iron Stove in Outdoor Workshop- Problems??[Hearth.com] Cast Iron Stove in Outdoor Workshop- Problems??
That's very beautiful work and a great father/son project. Still making a fireplace just to house a small stove is a bit odd. At least it should have been sized for a big stove, no?
I suppose I could have gone a but bigger but I'm not too concerned. I think I should be able to get enough heat from that size stove. Haven't ruled out insulating all together.
The F3 will be working it's tail off to heat the place when it is 20 outside. It has too tiny a firebox to sustain that kind of burn for more than an hour or two. But cold never happens in Ontario, so not a problem, eh? Will an F8 fit in there? There are versions without an ashpan. Or maybe an F118?
What is going in the cement block openings below the windows?
Haven't decided about that yet. Was thinking some sort of decorative wooden inlay. Faux doors maybe.
Like I mentioned I'm not really looking for a super warm/cozy environment in there. Just enough to comfortably work in a sweater maybe for a couple of hours at most. The opening is only 27 inches high at the corners so that limits my options. I understand where you're coming from though.
you probably would be better of with an old potbelly
My cast iron Shelburne lives in a cabin. I'm only there once a month or so. When it's cold, I start a small fire with kindling, just to let the stove warm up slowly. Then, after 30-45 minutes, I spread the coals and light a full fire. After five years, I don't have any crazing of the majolica finish or any other problems.
That is some nice log work there. Full dovetail notch, very unusual. Nice.
