It all depends on the type of steel you are referring to . There is a cold rolled steel category that is a 1018 Rc 5 to 20. That stuff is crap and is about as stable as balsa wood. There is also a hot rolled variety of steels as well as forged steel, which is the most desirable process for parts manufacturing. There is 4140 heat treat, 300 series stainless, 600 series stainless, 400 series stainless and a lot of exotic steel alloys.From what know cast iron can take a slightly higher temp before melting,but cast iron cracks much easier and is much much harder to weld. All things considered Ill take the steel any day.
Or stoves. Window mounted home burning stoves with bad burn pots. Pet food and baby formula.It all depends on the type of steel you are referring to . There is a cold rolled steel category that is a 1018 Rc 5 to 20. That stuff is crap and is about as stable as balsa wood. There is also a hot rolled variety of steels as well as forged steel, which is the most desirable process for parts manufacturing. There is 4140 heat treat, 300 series stainless, 600 series stainless, 400 series stainless and a lot of exotic steel alloys.
Cast iron is the same. there aren't as many varieties but the quality is most important. The volume of sand in the casting and any voids within the casting degrade the life of the iron, leading to it being fragile, and will lead to cracks and breakage. China is not known for being a source of quality castings.
I agree for the most part but some responsibility lies with the parent company as well. High quality requires extra scrutiny and oversight in China. Look at Apple, you'd be hard presses to find people who think an iphone is poorly made.Or stoves. Window mounted home burning stoves with bad burn pots. Pet food and baby formula.
For the most part however, companies outsource solely for the all might buck. However there are a few companies that do it while still retaining quality.
You know what a P61 runs and feels like, the same as your P43, just a bit bigger and slightly hotter when burning really hot ( more surface area). Do they have an XXV at the stove shop they could fire up for you and you could experience first hand ? Then instead of guessing how a cast stove feels you will know.I was debating on harman xxv or p61, either way if a kid touches the heat they are going to jump
The xxv won't scold you if you touch the stove at full blast, the p series will. The xxv radiates nearly no heat as compared to the p series.
It appears to me that the back and top of my Sabrina's firebox are cast, while the sides are stainless, as is the rest of the body. On the outside, the top and vent area are cast as well.Does Piazzetta have cast body stoves? Or just portions of?
