I have been burning a Quadrafire 3100 for about 4 years now since I bought my home but the stove seems to be a bit undersized for my home, which was more evident this year with the winter we’ve had in PA, so I’d like to upgrade to a blaze king princess this year. I have done a lot of research on here about the difference between catalytic and reburn stoves similar to what I have now and it seems like there is a lot of conflicting information in what I’ve read about the burn times at a higher output.
A lot of what I have read says that the burn times and wood consumption of the two stove types will be very similar at a high output but also at the same time a lot of people say they only need to reload every 12 hours with a princess in single digit temperatures. This is pretty drastically different from what I’ve experienced with my reburn stove which typically only has about 3-4 hours of good heat in each load and would need to be loaded 5-6 times per day in single digit temperatures. Can I actually expect good heat output from a catalytic stove like a princess 8 or more hours into a burn at a higher output or is it really going to be more similar to a reburn stove where I’m getting 3-5 hours of heating followed by coaling and cooling off up to 12 hours?
![[Hearth.com] Catalytic burn times [Hearth.com] Catalytic burn times](https://www.hearth.com/talk/data/attachments/346/346256-d33a88d95754d1437b3351adddaffbc7.jpg?hash=cy3msGTUiE)
