Thanks man last question is does the caulking have to be any silicone type based or is there a special one I need?
I don't think the upper flange should be cut off.You don't fold over 4 flaps and nail to the roof. Cut the upper edge flush with the opening. View attachment 115806
The Box has nothing to do with keeping water out. The flashing is what makes it weather tight.I don't think the upper flange should be cut off.
The the flanges should be nailed at the outer edge all around. Then shingle over top avoid nailing through the metal any lower then your original nailing.
I believe if the upper flange is cut a leak may occur. If he has a leak in a year or two he will be up there caulking frequently to stop the leak.
He did a neat job cutting an placing the shingles but if that metal flange was cut off its gonna be a problem. Probably after the caulk dries and cracks.
Sorry my bad. I thought he was saying to cut the flange on the flashing.The Box has nothing to do with keeping water out. The flashing is what makes it weather tight.
The slots are for ventilation, the storm collar should keep the rain out. It's rare to have an issue from the ventilated flashing.
I assume you aren't using Super-Vent then? Because it will not fit through the flashing with the pipe support clamp on it. Unless you can get into the attic to put it on, it won't work this way.I came up with a way im installing support and pipe after flashings already been installed!
Okay guys got it in today man that was an all day event. Here a a few questions. First off is it okay that I am at exactly two inch clearance? Please tell me the codes are not written more then 2 inch because there was a stud in the way. I did not bring the box up through instead since my cathedral ceiling is double studded I boxed it in on the top and bottom there are like 20 2 and 1/2 inch screws hold that sucker on. My first question is that I applied roof tar to the bottom and top of the storm collar. However, I noticed that from the inside you can move the chimney up and then down? Is this okay or did I miss something please please tell me know. Also, when I put the flashing in I noticed that there were three layers of shingles I got under all three but when I cut them, they were about 1/2 inch from being flush to the round part of the flashing. So, I just roof tared the gap. Lastly, I did what I though I would do, I did not leave room for the removal of the flue pipe. However, I can move the chimney u so is it okay to remove it like this or do I need to buy a telescoping piece of single wall pipe. However, the fit is designed to fit a 2 foot section perfectly? So maybe if I get two one foot sections there will be enough slack or no. My thinking is if it is okay to move the chimney pipe up I do not have to worry about the flue telescoping part? Also, when I went to lock the pipe adapter by turning it I ended up turning the whole chimney again will this mess up that tar around the storm collar I think yes?
My main concern is if I should lift the chimney to put the two foot section of stove pipe in or no just buy a telescoping part ist there one that size thoughThanks
Sorry for rambling but am new at this!!
)I assume you aren't using Super-Vent then? Because it will not fit through the flashing with the pipe support clamp on it. Unless you can get into the attic to put it on, it won't work this way.
Filling that gap is a good idea. There is no reason to remove it.What about the roof tar going up the circular part of the flashing? should I remove that and the roof tar going around the circle part of the flashing?
Also, is alforit it right should I not have filled in that gap on the flashing between the shingles and the circular part of the flashing. since I did should I remove it?
A good quality silicone adhesive/sealant like GE Silicone II is what I have used.Thanks man last question is does the caulking have to be any silicone type based or is there a special one I need?
Just put some roofing cement around the top portion of the flashing boot. I have had issues with leaves and debris getting stuck there if its left open. After a few years silicone pulls away but good roof cement stays put.Mine did come with the sealant already there but I read somewhere that you should put extra as this leads to problems years down the road. Is the tar okay there and around the circle part of the gap between shingles. Just want to check will be on roof soon. Thanks again.
