I'm in the process of installing a pellet stove in my house.
I'm going to test fit my piping to make sure its how I want.
I want to go back over and seal each of my connections with hi temp caulking or some kind of tape.
My question is should I lay a bead of caulk in where the rope lies then lock it together and go back over the outside of the connections with some more caulk or tape?
Should I still run some self tappers into pipe or is this not needed with the use of caulking?
Also I've heard some ppl say to pull the rope closer to the edge with a pick or similar tool then connect the pipe, is this a necessary step?
Is this overkill? Sorry I think I'm over thinking this but I only want to do this right once with out headaches down the road.
