Ceiling Clearance and how to finish?
Vizzy92
9
North East USA
Hey all,
So, I recently purchased a home with an old wood burning stove in the basement that I had a fire in and the ceiling got way too hot. So I pulled down the drop ceiling and all the "brick" that had sheetrock behind it. Attached are some pictures with a rough idea of how far away the pipe is from the floor joists above. Please note that this single wall pipe is going to be changed to a double next week to help reduce my clearance. Do I have the proper clearance and if I do, how can I finish the ceiling?
Really appreciate any help!
Thanks,
Viz
[Hearth.com] Ceiling Clearance and how to finish? [Hearth.com] Ceiling Clearance and how to finish? [Hearth.com] Ceiling Clearance and how to finish? [Hearth.com] Ceiling Clearance and how to finish?
It will be close depending on the brand of double-wall stovepipe. Some have a greater vertical clearance. DuraVent DVL is 8". Selkirk DSP and Excel UltraBlack are 6".
If you want to reduce dramatically reduce wood consumption, insulate the basement walls. Up to a third of the heat generated is getting sucked out of the cold cement walls. That's one cord out of three burned.
Reactions: Vizzy92
Ahh okay so hopefully the people doing it use the stuff that makes it a 6" clearance.
Also, I'm re-doing the basement, so that'll have some nice stone backing it along with finished drywall and what not :) Thanks!
They did not that is just single wall pipe which needs 18"
Reactions: Vizzy92
It does look like they ran class a pipe through the wall though which is good
Reactions: Vizzy92
It's good that you noticed this and have double-wall on order. Ask them what brand pipe.
Reactions: Vizzy92
