Should be ready to start closing walls up in the coming months and trying to make sure I stuff everything in them before I do it. Any thoughts on whether central vac should be on the list?
And the # 1 reason I love my central is it's sooo much more quiet than any other vac when in use.fire_man said:Reasons I really like our central vac:
More power than a portable Vac
Much less frequent emptying of canisters
Filthy Vacuum air exhausts outside
Less weight to drag around the house
Nice option when you go to sell the house
Fun to chase dog around the house with long hose
SolarAndWood said:This house rebuild has been a pretty good $$$ bleed for a few years now. Just don't want to miss something while I am closing up that I regret the rest of my life because knock on wood this is the last house I am doing.
fire_man said:Mine was easily installed after the house was already built. It's two stories, both floors have the vacuum service.
Why not just install the plastic pipes and wires before closing up, then if you decide later add the power unit and accessories?
fossil said:If it's the "wired" flavor...so when you plug the hose into the wall you're also plugging in a power connector, then a power driven roller brush will work with the system. That's the only way I would have one. I've had two different central vac systems in two different houses...one with the power feature and one without. Without, then the best you can get for a roller brush to help clean carpets is an air turbine operated thing which is basically worthless. If you've got a powered system, you can actually do some cleaning. If you have no carpets or rugs to clean, then don't bother with the powered system. Yes, it's nice to just carry a hose from room to room. If I were building a house, I really doubt that I'd spend my $$$ on it, unless I just had a bunch of money I didn't know what to do with. %-P Rick
fire_man said:Why not just install the plastic pipes and wires before closing up, then if you decide later add the power unit and accessories?
That is very true. I don't like it when I'm working in the yard and the wife kicks it on, very annoying. But inside it's quiet compared to any other vac we've used.BeGreen said:That's ironic. We live in a quiet neighborhood and I know exactly when my neighbor's central vac is running. It's quite loud even though it's about 400 yards away.
bostonbaked said:And the # 1 reason I love my central is it's sooo much more quiet than any other vac when in use.fire_man said:Reasons I really like our central vac:
velvetfoot said:Doesn't stuff ever get stuck in there? How would you get it out?
