Hello everyone,
Recently I have run across a wood stove that I really liked (Drolet HT2000) and replace my older stove(Fisher Grandpa Bear). However, the new wood stove requires a 53" clearance from the stove top to ceiling according to its manual - Which I do not have. Due to the raised floor (which can not be removed) and the brick hearth already in place, I have 47 inches of clearance left (short by 6 inches).
I am aware that a 28 gauge of sheet metal suspended with a 1 inch spacer will reduce the required clearance but since the stove is located in the foyer of my home, I think it will not look so aesthetically appealing and kind of ugly. Going for a smaller stove or other stove models is not a real option either, since I have not seen any other model that I liked over the HT2000 with its abundance good reviews.
QUESTION: Can a ceramic fire blanket be attached to the ceiling to act as a heat shield and reduce my clearance? since the ceramic blanket is white, it will blend in much better with my ceiling over a suspended sheet of metal which can not be painted.
It seems this topic of ceiling clearance is nearly non existing or not as popular and is the reason I wanted to post it- in case others had the same issues and possibly someone to point to something about ceramic fire blankets that I was not aware of.
Lastly, If ceramic fire blankets can withstand constant and continuous direct fire without heat going thru it, why is it never mentioned or used as a heat shield to reduce clearance on a combustible wall or ceiling for a wood stove? is there something I am not aware of?
Thank you all
Thank you all
