Chainsaw for private use
I've never used the m-tronic so I couldn't tell you, however I'm sure other folks will reply with their experience.
Worth buying with m-tronic?
If both are available to you I would skip the m-tronic....more expensive to repair as it is a on board microprocessor which costs more to replace than a carb....I have 3 Pro 260s(Yeah i like them! lol)....2 are pre epa and the one is the m-tronic....never had a issue with any of them...quicker throttle response with the m-tronic is the only difference I see and its a small difference thats barely noticable to me.
I checked online for local retail prices:
  • Stihl MS 261 CM - $580 --> 50 cc pro grade saw at 10.8 lb. w/ M-Tronic
  • Husqvarna 565 - $900 --> 70 cc farm grade saw at 14.3 lb. w/ Auto-Tune
Someone is selling 565 for about same price as 261 ?
Different saws - not apples:apples, but it would seem that the 565 would be a good vale at 261 price.
Both Stihl & Husky are great saws. At some point it comes down to what will work best for your needs.
Reactions: JimBear
Consider the diameter of typical wood you'll be cutting. Use the shortest bar practical for your needs (good for 85% your cutting).
If cutting for full time wood heating I'd consider 50 cc as a minimum (16"is good bar length match, with 18" bar a max). You can always buy a longer bar to use when needed. But longer bar = more drag.
I've used both manual carb and electronic governed (M-Tronic or Auto-Tune), which are typically offered on pro saw (non-homeowner) line. These have noticeably better throttle response. I'm partial to pro line saws if you can afford/ justify.
Thank you for the reasonable post, unlike others who randomly start talking about milling saws...
Reactions: sloeffle
Something to consider between those two is weight. I consider myself a fairly fit person, but cutting a load with my Jonsered that weights 14 pounds tires me out more than cutting a load with my Stihl 250 that weighs 10.8. Some folks don't care about that, but the lighter saw is easier to manage over a longer period of time. Either way, post up some pics of the new saw when you get it.
A 565 is quite a bit bigger than the 543xp and 545 you started off looking at.
What size and how much wood do you plan on cutting? I'd have a hard time justifying a 70cc 565 as a firewood saw.
No problem for me to use tools with weight ~22pounds.
As a result I bought husky 565 for 800$ when 261 i could got for 780$. I also bought 2nd chain chisel and 1l of oil.
After few first cuts i can say it's absolute beast.
Reactions: JimBear
Reactions: JimBear and Gouran
I think the MS261 would fit your needs well.
I'll throw another vote for the 261
I'll throw another vote in for the 261. I have a 261 and a 362 and I grab the 261 almost all of the time. The thing cuts! I cut a mix of hard and soft woods--probably 7-8 cords a year. I can cut an 18 inch tree or more with no difficulty, but the saw is light enough to limb a tree without much fatigue. I don't have the mtronic version. I estimate that I have cut about 50 cords with the saw and outside of routine maintenance (clean bar, filter, new plug, etc.) the saw has not needed anything.
Reactions: Zack R and JimBear
