Thanks ScottyThe lower grade fuel really isn't good for your saws. The local Stihl dealer has an aviation license and he sells AvGas (ethanol-free 101 octane, I believe) but it's really salty (somewhere around 8 bucks a gallon). I have all older saws, most of them were rebuilt and customized by me. I run 89 or 92 in them, but I mix a tad more oil than others as well (around 40:1) to help the saw get a little extra lube due to the ethanol being in the gas now. I've not had any problems with my saws, but occasionally I DO get some of that AvGas and after a retune on the saw, what a HUGE difference in power.....honestly, it makes that big of a difference. Something to remember is when you run a better gas in your saw, you WILL have to retune it because most likely the saw will be running rich. Same goes when you run lesser gas in your saw, chances are you will have to richen the carb because of the lower octane rating. Something else to keep in mind, OPE was NEVER MEANT to be run with ethanol gas in it. It will do OK with the 10% fuels, but it will NOT live very long running 15% or higher.......Just some food for thought...
Well ! I guess I will have to find out who is selling what kind of gas , around here, It's suppose to say the, ethanol % , on the pump, isn't it ??
I made the switch just recently too, from running 87 octane regular 10% Etoh, to running 90 octane Etoh free. It costs about 65 cents more per gallon here, and there is only one place to get it in Ravenna about 12 miles away. I figure its worth the little bit extra, my saws seem to really like it! Like TreePointer, I have some saws that say to use it, so I'm just going to feed it to all of them.
While they don't tell you the actual percentage, the sticker should say something like "Contains up to 10% Ethanol"
who has ethanol free gas in ravenna? I;ve been all over the state for work and haven't seen one in almost a year now.
If you have to use ethanol fuel, only mix up a gallon or two at a time. The ethanol attacts moisture like no other. i would not personally use it after sitting more than 2weeks, 3 max. Also, Do not leave any ethanol fuel in ANYTHING. no chainsaws, mowers, weed eaters, snoblowers, etc. you will be replacing rotten fuel lines, and rebuilding plugged carbs. this new fuel sucks and is very hard on anything that has rubber, aluminum, brass, plastic (carbueretors, fuel lines, tanks,etc)
...............................None of my older saws run so haven't seen ethanol...................................
Here is a web site that lists gas stations that sell pure gasoline by state and province (two listed in Ravenna, OH):
http://pure-gas.org/
With the ethanol fuel do you guys still have issues with fuel lines freezing up? My tractor that has a snowblower on it seems to collect a fair amount of moisture in the fuel and end up freezing in the float bowl of carb. Since adding in a splash of methanol with every fill I haven't had any trouble.
