Hello all.   I am trying to get some information and nobody really seems to know anything about these things.  I bought this house 2 years ago and it has a charmaster furnace.  It has an oil burner in the side which is what I've used to heat for the last 2 years and it has worked fine. 2100sqft house and I used around 800 gallons of oil.  Well with oil at $5/gallon I decided to see how the wood portion would work today.   I got the fire going no problem.  I have 2 thermostats in the wall so I assumed one was for the oil one for the wood.  I left the oil one off.  Well once the fire got hot the blower kicked on. Cool.  Now I started checking temps at the stove pipe,  I left the damper open on the top pipe to get heat in the pipe as it's not too cold and didn't pan on getting a rip roaring fire going.  Well it was about 150 degrees.  That's too cool.  Looked at the fire and it was barely going,  I see that the front door has an air inlet door, it has a chain that's attached to a hook that goes into a little plenum on top of the stove, chain is slack so it just leaves the door closed.  So I tighten the turn buckle to keep the air inlet door open about half way.  Cool for kicks up got the stove pipe to about 300 degrees.   But the blower runs constantly.  Also there's a draft pipe by the chimney so the pipe is much cooler by the chimney.   So a few questions.
Is the blower supposed to run constantly when burning wood? It didn't on the oil side.
Is that air inlet door supposed to be automatically controlled?
What temp is good for the stove pipe, should I close the damper force the exhaust to the lower pipe and give it more air to get it hotter?
I had a wood stove at my parents when I was a kid and am nervous about burning wood don't want to burn the house down and kill anyone.. they had a fire once, not fun. But these oil prices.... rock and hard place.
 ![[Hearth.com] Charmaster wood furnace [Hearth.com] Charmaster wood furnace](https://www.hearth.com/talk/data/attachments/302/302837-4e97899e2959250a5f138b6665b5799a.jpg?hash=K5HqTV_GpK)
