Cheaper US Stove Part for Clayton
thundar
38
SE Ohio
Hey guys, I would love to buy a new forced air blower for my Clayton 1600G wood furnace, but US Stove's website says the replacement is $205 for a little 4" fan blower. Any ideas where I can get one cheaper? The old one still works, but the switch went bad, and I replaced it with a switch, but it is impossible to keep the wiring together (it's jammed in a 1" by 2" box with no slack wire to work with).
Try Grainger.
Thanks, I will check it out.
Not sure about your actual furnace, but mine had the dual blower fans. When they went bad I replaced them with a large single from an old propane furnace that a buddy gave me. I cut a hole in the back to accommodate the new size and I was off and running. Personally I wish I had done it years ago. For what it's worth I also made my own shaker grates and shaker grate holders instead of buying there way over prices replacement parts. Good luck
Edit: I'm talking about the distribution blower
Are you talking about the distribution blower, or forced draft blower?
The forced draft blower. It still runs fine, but the switch went bad a few years ago, and US Stove (of course) doesn't sell just the switch. And you can't get in there to get good wire nut connections on it, so the hot wires want to jiggle loose sometimes. It's a pain.
