What kind of brush do you guys use, poly or metal? I am leaning toward poly cause it won't be so abrasive to the pipe. I figure I would have it done once by a professional and watch then do it myself
If its in a stainless chimney or liner, only Poly, if in a clay tile metal. My Liner said warrenty VOID if anything besides a POLY brush is used.
That doesnt make it right! Did you see the post by pallet pete where the pro used the "chain flail" on his buddies SS linerI use a metal wire brush on a 6 inch stainless steel ventinox liner. The professional stove installers said that is what they use.
On the boxes of the wire brushes that are available in my area, it very clearly states that a wire brush is meant only for a clay liner --do not use on a SS liner.I use a metal wire brush on a 6 inch stainless steel ventinox liner. The professional stove installers said that is what they use.
Rolling eyes. Here we go again, every gdamn year.
Ed do you remove and inspect / clean all the tubes in your Osburn when you pull the baffle? I don't - just wondering if that's worth the extra few minutes....?Poly on my ss liner. Very easy to do it takes me about a half hour that including removing the baffle in the stove.
Yes, I have to remove my front two tubes to get the baffle out so it was worth the look. This is the first winter for this stove so they were obvioulsy clean. Maybe the next year or year after that the far back tube will be pulled and cleaned.Ed do you remove and inspect / clean all the tubes in your Osburn when you pull the baffle? I don't - just wondering if that's worth the extra few minutes....?
i think he is more referring to why dont more folks use the search feature before posting? But really i dont mind seeing it more than once, i too have asked questions that have been asked more than once. I try to look at searches but the tangents we go on sometimes make them not as productive without reading for hours. Just like i am posting here!If you don't like to see questions repeated then you probably shouldn't spend so much time on an internet forum.
Somebody said:Rolling eyes. Here we go again, every gdamn year.
Clemsonfor brought up a good comment. To add to that, I've posted on here before about this. The last time we put up a new chimney (SS) just for kicks I asked the man at the stove about steel vs. poly. He has worked at this for many, many years (don't remember exact so will just say many). His comment was that you indeed could use either but.... In his years of working with this stuff, the only SS chimneys he has ever seen that had to be replaced were the ones where the owners used steel brushes. Never any damage with poly. He did say no damage appeared much at all until close to 20 years but by 20-22 years they had to replace.
With that comment, I simply figured, why not buy a new poly brush for $15. Sure, I have the steel brush but probably will never use it again. For a lousy $15 I'll go with the idea that it won't damage the SS.[/quot
Thanks, I will look into it. You know in 20 years I will be 80![]()
I use a poly brush. Somewhere I seen a wire brush will scratch the stainless and rust will start and creosote will build up faster.
