Chimney caps
black smoke signals
409
Wyoming Colorado
For those users with High wind chimney caps (dealer suggestion to buy) using a Vacu-Stack 6inch cap Pros and cons! All I can see is this style cap controls down draft but how does it control wind and still maintain min -max draft? (broken link removed to http://www.woodlanddirect.com/Vacu-Stack-Wind-Resistant-Chimney-Cap?gclid=CMnL7deZwtECFQkOaQod48sF5A#Vacu-stack%3A6%22)
I would avoid those caps if at all possible yes they work to limit any nevative effect of wind on your draft but they are a real pain to clean
Are you saying the top horizontal pipe can creosote up or plug? Have a cap in mind that will help my application that is easy to clean from inside the house?
The wind directional cap, i.e., "rooster tail" or "roman helmet" caps work well until they gunk up with creosote. In places, like on the coast & close to the beach, they are almost a requirement due to wind issues. They are easier to clean than the one you are looking at. Go SS if you should get one of those wind-directional types (they are worth the cost), & the simpler the bearing in it the better, as a bushing bearing doesn't gum up as fast as a ball-bearing or roller bearing.
