I will be installing a Pacific Energy Super 27 this spring in my fishing camp (replacing a dreadfully scary potbelly in a place I bought 2 years ago). I need to replace the current chimney as well. The options listed in the PE manual for chimney choices are listed. I am guessing they are all pretty much equal in application but wondered if there are any subtle differences that make one or two better than the others. I am located in Southern Ontario and my camp is near North Bay. Warranty all seem pretty much the same. I will be installing this myself and having it WETT certified after. My place has an upstairs sleeping area which the current chimney goes up through the pine T&G;floor and then through the roof. I understand I will need heat shielding around that section upstairs (which is currently not there). To be 2' above the peak I believe I will require 14' of chimney. (boat access only so won't be there until spring to confirm). I already have a double wall telescoping pipe to connect from the stove to the chimney.
Thanks in advance for any the guidance
Security S2100
Pro-Jet H.T.3000
ICC Excel 2100
Selkirk Sentinal CF
Energy Vent Commander 5000
Security S2100
Pro-Jet H.T.3000
ICC Excel 2100
Selkirk Sentinal CF
